High Cpu Usage - Spammed by meta?
I seem to be getting spammed by these
57.141.16.24 - - [20/Apr/2026:04:00:50 +0800] "GET /cart/?remove_item=bfd2308e9e75263970f8079115edebbd&_wpnonce=87af8e445c&add-to-cart=4571 HTTP/2.0" 200 1452108 "-" "meta-externalagent/1.1 (+https://developers.facebook.com/docs/sharing/webmasters/crawler)"
57.141.16.45 - - [20/Apr/2026:04:00:50 +0800] "GET /cart/?remove_item=a927541d74113c53810fb0b383a649ac&_wpnonce=c5368d0313&add-to-cart=4571 HTTP/2.0" 200 1452108 "-" "meta-externalagent/1.1 (+https://developers.facebook.com/docs/sharing/webmasters/crawler)"
57.141.16.92 - - [20/Apr/2026:04:00:51 +0800] "GET /cart/?remove_item=752d2c9ecfe079e5e5f3539f4d750e5c&_wpnonce=54da3d2995&add-to-cart=4619 HTTP/2.0" 200 1452212 "-" "meta-externalagent/1.1 (+https://developers.facebook.com/docs/sharing/webmasters/crawler)"
57.141.16.100 - - [20/Apr/2026:04:00:51 +0800] "GET /cart/?remove_item=752d2c9ecfe079e5e5f3539f4d750e5c&_wpnonce=c7f9ae23ba&add-to-cart=4521 HTTP/2.0" 200 1452118 "-" "meta-externalagent/1.1 (+https://developers.facebook.com/docs/sharing/webmasters/crawler)"
I have no idea why, in 1 week this particular user has consumed 5TB of data. And by analysis it seems to be spamming from facebook. Any idea what i should do?
I have tried disabling the meta pixel does not seem to change anything.
If that’s the real facebook crawler, you could add this to your robots.txt (it should respect it):
[other rules]
User-agent: meta-externalagent
Disallow: /cart/
Disallow: /checkout/
Disallow: /*add-to-cart=*
Disallow: /*remove_item=*
Disallow: /wp-admin
5TB are a lot for a stupid crawler, I would have blocked the IP range 57.141.16.0/24 days ago.
I ended up blocking the IP range and updating the robots.txt, and that seemed to have stopped it for now.. I saw on reddit that recently theres an uptick of meta crawler for AI. But this is the most aggressive i have seen in sometime, maybe it was broken.
Check my posts here. I had my servers freezing due to several AI crawlers, and them not respecting the robots file. I ended up blocking 10K+ bot IP’s and ranges.
link please
Topic
I had issues, and @sahsanu directed me towards resolution as well.
On the last weeks I have been fighting against that issue on online shops. I tried robots.txt and HestiaCP firewall but I just solved it using cloudflare with the folowing firewall rule set to “managed challenge” as action
(cf.client.bot and not http.user_agent contains “Googlebot”)
or http.user_agent contains “facebookexternalhit”
or http.user_agent contains “Facebot”
or http.user_agent contains “meta-externalagent”
or http.user_agent contains “meta-webindexer”
or (
http.request.uri.query contains “filter_”
or http.request.uri.query contains “query_type_”
or http.request.uri.query contains “add-to-cart”
or http.request.uri.query contains “add_to_cart”
or http.request.uri.query contains “add-to-wishlist”
or http.request.uri.query contains “remove_item”
or http.request.uri.query contains “_wpnonce”
and not cf.client.bot
