Hi! Do we update Hostgator versions @Raphael ? And how to know the current hostgator version installed?
I hope you mean Filegator?
In that case
We update it during each hestia update.
In case of Hostgator ask their support…
Ok, thank you.
How does Hestia add editable files to /usr/local/hestia/web/fm/configuration.php ?
Hestia config is different from hostgator
If you run 1.6.2 it should be the last version. If not update Hestia to the last version
hm look like github bug.
I found how.
Sorry
