Hostname is not the right one
https://ubuntu-hestia.localhost:2083/login/
I have this in the welcome mail and in the browsername, but when i do a hostname check it is the right one. How can i change it so users receive the right hostname
You should add the hostname under the config server of HestiaCP (as the admin user). You will find the “Host Name” field out there. Substitute the values on the following URL:
https://IP:port/edit/server/
After adding the hostname in this “Host Name” field, HestiaCP will use it as the main domain and insert it in emails sent to users.
I know that, and i have changed it already . But it is not working. When i opening my dashboard i see in the chrome tab also the old hostname while i have changed it in the server settings.
See
