I have several domains included on my server with Hestia Panel, and there are some that have the Antivirus and Spam Filter activated and another are in red. How can this be solved?
I attach images.
I attach images.
Click in the mail domain name and in next screen click on Edit mail domain button and you will see the options to activate Antivirus and Spam Filter (remember to click on Save button to apply the changes).
v-list-sys-services
v-list-sys-services
NAME STATE CPU MEM UPTIME
apache2 running 0 460 366
php5.6-fpm running 0 7 40667
php7.0-fpm running 0 7 40667
php7.1-fpm running 0 7 40667
php7.2-fpm running 0 7 40667
php7.3-fpm running 0 7 40667
php7.4-fpm running 0 7 40667
nginx running 0 26 9005
bind9 running 0 43 367
exim4 running 0 2 366
dovecot running 0 0 366
mariadb running 0 612 76640
vsftpd running 0 0 40667
cron running 0 0 76639
ssh running 0 2 1
iptables running 0 0 0
fail2ban running 0.1 137 76640
Both spamassin as clamav (Anti virus) are not running…
There was an bug in te past where it was possible to enable it how ever it did never work…
And is there a way to solve it, because I have other domains that are activated.
Install both services …
For the domains that are acitivated they also currently don’t work…
How should it be done, or is it not necessary?
I am facing same issue.
I just started to test this.
Any resouce link to handle this.
@ClaudioSpcSpa did you resolved this? How?
Make sure to install them and have more the 4gb of memory
