How can I enable shell_exec?
Hello. Please, friends and experienced people, help me solve this problem that is exhausting me. How can I enable shell_exec?
shell_exec() has been disabled for security reasons, please contact your host provider to enable it.
shell_exec is required to enable this system.
Keep in mind that enabling shell_exec could be a security risk.
Edit the php.ini file for your php version and mode (cli and/or fpm) and remove shell_exec from disable_functions directive.
Example for php 8.2 version:
CLI: /etc/php/8.2/cli/php.ini
FPM: /etc/php/8.2/fpm/php.ini
Before removing shell_exec:
disable_functions = pcntl_alarm,pcntl_fork,pcntl_waitpid,pcntl_wait,pcntl_wifexited,pcntl_wifstopped,pcntl_wifsignaled,pcntl_wifcontinued,pc
ntl_wexitstatus,pcntl_wtermsig,pcntl_wstopsig,pcntl_signal,pcntl_signal_dispatch,pcntl_get_last_error,pcntl_strerror,pcntl_sigprocmask,pcntl_sigwaitinfo,pcntl_sigtim
edwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority,exec,system,passthru,shell_exec,proc_open,popen
After:
edwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority,exec,system,passthru,proc_open,popen
After that, restart php service.
systemctl restart php8.2-fpm
Thank you for the quick response. Please, where is the option or place in hestiacp to modify it?
Server settings β†’ Edit the php service (use the pencil icon shown when hovering the service name) β†’ Advanced options (here you can modify php.ini file) and once done β†’ Save
The problem was solved successfully. Thank you, my friend, for helping me.
