I have already installed WordPress through Quick Install and is running without any problem. When I try to install NextCloud through Quick Install it asks for deleting files in public.html where WordPresss files take place. Is there a way to install and run two apps on the same server?
Subdomain is the way.
Thanks a lot for your kind support.
Thanks for your kind reply.
