If MariaDB 10.4 is installed on the server, can I upgrade to version 10.5 without reinstalling HestiaCP? Will this affect the correct operation of the web server configuration?
There is a auto upgrade script, you can trigger it with the following command:
bash /usr/local/hestia/install/upgrade/manual/upgrade_mariadb.sh
Usualy, it should work out of the box, but every upgrade is a risk. So something could fail and you would need to debug it.
I run the script and the upgrade was successful. Everything works. Thanks!
BTW, don’t upgrade, if you run on a low spec. server. Mariadb folks in their wisdom decided to make the minimum specified connections an arbitrary 10. This is not good, if you are memory constrained, as I discovered recently. Had to rebuild a VPS with mysql 5.7 instead. :’(
