How can I increase it, I really don’t know, I want to access the root of hestiacp
If its for a website, create a .user.ini file in the web root (public_html usually) and add the values to that. eg
post_max_size = 55M
upload_max_filesize = 50M
If its for webmail you’d have to add/edit /var/lib/roundcube/.user.ini (or equivalent in rainloop)
In 1.6.8 we are going to update the default values to 100mb
