How can I use a domain exclusively for the HestiaCP panel ?, go from iP: 8083 to mydomainpanel.com . And apart from that (In case it is possible) to be able to disable access by adding: 8083 to my domains parked in the panel, in advance thanks.
eris
April 19, 2021, 1:10am
2
Check out:
cp.stpl
# Default Web Domain Template #
# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS #
server {
listen %ip%:%proxy_ssl_port% ssl http2;
ssl_certificate %ssl_pem%;
This file has been truncated. show original
cp.tpl
server {
listen %ip%:%proxy_port%;
Then disable port 8083 in your firewall
system
Closed
May 19, 2021, 1:11am
3
