good! I have to use php 5.3 for a website that I have to migrate. How can I make the hestiacp work?
In vestacp there was a script that installed any version of php, does it exist in hestacp so that it can be used as an apache template?
Other versions are not supported. Please note that php 5.3 is allready for about 3 to 4 years EOL
With version 5.6 it works for me, how do I install the php multiversion in a working panel?
Where version is x.x
wow thank’s!!
Closed topic
PHP 5.3 would help me with some older e-commerce packages but I recognise it’s of limited use. (Expensive) CloudLinux to the rescue.
Thanks for the command list link - bookmarked.
Adding/Removing php versions can be done using the web interface too
(Server -> Configure -> WebServer | https://my-panel:8083/edit/server/)
