How do I enable proc_open
I enabled proc_open in etc/php/x.x/fpm/php.ini. As well as at Hestia’s control panel.
phpinfo() also showed that proc_open isn’t disabled.
However, errors occur when installing projects with composer, with the message “proc_open is disabled …”
Where else should I change?
In /etc/php/x.x/cli/php.ini
Hello;
I have the same issue overhere, however no disabled modules in
both /etc/php/8.2/cli/php.ini nor /etc/php/8.2/php-fpm/php.ini
Basicly for testing i have no disabled modules for all php versions configured from the advanced function inside the hestia admin panel.
However script under user still throws error: Symfony\Component\Process\Exception\LogicException: The Process class relies on proc_open, which is not available on your PHP installation.
Any idea how I can fix this please
Thanks John
Op /etc/php/x.x/fpm/php.ini
where x.x is you php functions
And check for disabled_functions
Hello Eris,
There are no disabled functions in my php.ini files as i deleted all available functions.
This might be blocking somewhere else by a lock file as i have understood in a post i read earlier but cant find out how to do that on hestia,I installed hestia only last night.
My system is running debian 12,
But i read a post about a windows server with zpanel. that said following
The problem lied in Zpanel’s httpd-vhosts.conf file, actually i have a Windows 2008 Server with ZPanel and suhosin installed, so in httpd-vhosts.conf file there was php suhosin.func.blackblist = proc_open, so i commented this line, and restarted APACHE from services, Now its working flawlessly fine.
Any idea of that coud be the reason and if so where do i find the vconf files in hestia
Best regards
John
We only limit it in the /etc/php/x.x/fpm/php.ini
Make sure you checked the correct version
Hi Eris
Here is my portion of the concerned php.ini file aswell as the phpinfo to of the application
I have removed all disabled_functions from within hestia for all installed php under the advanced web configuration so no modules at all are disabled on the server for any of the php versions
; open_basedir, if set, limits all file operations to the defined directory
; and below. This directive makes most sense if used in a per-directory
; or per-virtualhost web server configuration file.
;open_basedir =
; This directive allows you to disable certain functions for security reasons.
; It receives a comma-delimited list of function names.
disable_functions =
; This directive allows you to disable certain classes for security reasons.
; It receives a comma-delimited list of class names.
disable_classes =
app.emailmarketinghub.eu/info.php
Open /etc/php/x.x/fpm/php.ini
find disable_functions = pcntl_alarm,pcntl_fork,pcntl_waitpid,pcntl_wait,pcntl_wifexited,pcntl_wifstopped,pcntl_wifsignaled,pcntl_wifcontinued,pcntl_wexitstatus,pcntl_wtermsig,pcntl_wstopsig,pcntl_signal,pcntl_signal_dispatch,pcntl_get_last_error,pcntl_strerror,pcntl_sigprocmask,pcntl_sigwaitinfo,pcntl_sigtimedwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority,exec,system,passthru,shell_exec,proc_open,popen
change:
disable_functions = pcntl_alarm,pcntl_fork,pcntl_waitpid,pcntl_wait,pcntl_wifexited,pcntl_wifstopped,pcntl_wifsignaled,pcntl_wifcontinued,pcntl_wexitstatus,pcntl_wtermsig,pcntl_wstopsig,pcntl_signal,pcntl_signal_dispatch,pcntl_get_last_error,pcntl_strerror,pcntl_sigprocmask,pcntl_sigwaitinfo,pcntl_sigtimedwait,pcntl_exec,pcntl_getpriority,pcntl_setpriority,exec,system,passthru,shell_exec,popen
