I’m trying to transfer the HestiaCP VM to another IP by changing config files.
The panel has moved and works, but it is impossible to change IP in Web domains. Rebuild All delete config files, new domains get old IP.
Is there any way to do this, or I need to reinstall VM and HestiaCP?
