Hello!
Could you explain, i want not to do backup for one domain, try to fill:
- or . in exclusions but panel does daily back up again
Thank’s
PS Hm, forum brakes symbol shift + 8, i fill them in masks
(shift + 8).(shift + 8) or shift + 8
Hello!
Thank’s
Enter:
domain.com
Under web
And it should be fine
If i fill name of domain in web, all others sections will be turn off too (mail, db, user )?
No.
If you want to disable a backup of the user create an new package and set backups to 0
Thanks!
