how often do you run apt update and apt upgrade on debian (for debian)?
is it okay to run it weekly ?
last time i ran update and upgrade was about 2 weeks ago.
hestia shows is up to date.
Every day (several times). If there is a security patch you don’t want to have the services exposed with that security hole for one or two weeks.
i use “apticron” on my server. It sends me every day an email with available updates.
I gotta second this – apticron is literally one of the first things I install on my Hestia machines running Debian. This way you never miss knowing about an update including how severe it is and what the update contains.
@alinux always update and reboot when necessary.
I use the unattended-upgrades package configured to automatically install security updates.
I used to use apticron before I switched to unattended-upgrades. It was a good solution, too.
How long have you been running this setup and did you ever encounter an issue with incompatibilities or broken stuff (hestia, wordpress etc.)? Thanks!
I don’t know exactly when I switched to unattended-upgrades. It was sometime in the twenty teens, so at least five years. I only install security updates automatically. It was my default by the time I started using HestiaCP. I have had no issues with it on hosts with HestiaCP and WordPress. YMMV
