How to access Snappymail Admin?
Hey the default url of webmail.domain.com/?admin doesn’t open the Snappymail admin panel. How do I access the admin panel also How do I get access to the admin login credentials?
See the docs:
Can I login into the backend of SnappyMail
In the root folder, there is a file called .snappymail containing the username and password:
bash
Username: admin_f0e5a5aa
Password: D0ung4naLOptuaa
Secret key: admin_f0e5a5aa
You can access the admin by navigating to https://webmail.domain.tld/?admin_f0e5a5aa, and login by using the data you found in the file. Once it’s not needed anymore, remove the file, for security reasons.
