How to add automatic response filter to roundcube?
I am willing to pay up to 250€ for that feature and even more if we had sieve fully operational so that my clients can configure it via thunderbird.
From Thunderbird … Changes required I had to open 1 port in my firewall…
Perfect then.
The other issue that could be added to the bundle is the webmail performance optimization.
https://www.debianhelp.co.uk/perdition.htm
You are linking to a file from 2007 I assume most thing are already out of date due to changes in improved “coding” knowledge and automated compressions.
https://projects.horms.net/projects/perdition/
Unless you need to host a large client with over xxx mail boxes or extreme large mail boxes it probably doesn’t make sense adding. As it requires a large scale rewrite for no reasons as it act as an nginx proxy infront of you server for mail things…
Also it is not actively maintained for +5 years …
And the performance tweaks?
It is from 2007 so I assume they won’t be nessarry any more…
Roundcube is very slow now.
https://christiandietze.de/speedup-roundcube/ Might be an idea…
I assume it is mainly caused by the fact the connections are closed every connection
Also How to Convert Roundcube to SQLite | cPanel & WHM Documentation Might be an idea how ever no idea how easy executable it will be
I don’t think it will significantly increase performance and it is too complicated.
hey configuring that out of office reply in roundcube and having that as a component in roundcube would be great, is the above work estimation / offer still valid @eris ?
