How to add SSL to webmail domain using CLI
I have DNS records added such as “mail” & “webmail” and they already point towards the correct “A” records.
I know we can log in to HestiaCP GUI go to the domain edit mail, and add SSL.
Is there any way to add a Let’s Encrypt SSL to domain webmail using CLI as we do for normal domains? I don’t find any CLI command for in the DOC.
Thank you.
Have u tried v-add-letsencrypt-domain for your mail domain?
As @CStangerup said, the right command is v-add-letsencrypt-domain but as doc doesn’t provide too much details, the right command in your case should be:
Let’s assume your user is bikrama and your domain is example.com
v-add-letsencrypt-domain bikrama example.com '' yes
Above command will issue a Let’s Encrypt certificate for (mail.example.com and webmail.example.com).
Thank you @sahsanu It worked for me.
