How to allow mariadb remote connect hestiacp
I want to connect a database. from another server
how I can setup properly?
Just add a firewall rule allowing port 3306 from your other server, I suggest to limit it for his ip address and do not allow the connection from anywhere. Also validate the bind-address setting, see posts below.
this way
/sbin/iptables -A INPUT -i eth0 -s 145.239.00.00 -p tcp --destination-port 3306 -j ACCEPT
Or From HestiaCP
From hestia cp, checkout the firewall rules part.
I have this same problem. I installed Wordpress via Hestiacp and want to access my database remotely to display my blog posts within my custom app. I tried the solutions suggested here - opening ports both via Hestiacp and command line but still keep getting connection refused when using HeidiSQL or DBeaver to connect remotely. Do I need to do any more configuration to get this to work?
The question is if mariadb/mysql server answers requests from any ip, checkout this - I suggest the ā€œmanual stepsā€: How to enable Remote access to your MariaDB/MySQL database
Thanks for the suggestion. I’ve checked the link and followed the instructions but there is no ā€˜bind-address’ in the configuration file mentioned. When I add this line, it still shows as listening on 127.0.0.1 from netstat (tried restarting mariadb and rebooting). Do you know how to solve this?
bind-adress=0.0.0.0
That’s what I added, it didn’t work
Ok I’m using Ubuntu 16.04, I found a solution: I needed to change the bind-address in
/etc/mysql/mariadb.conf.d/50-server.cnf
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
