Best regard.
In the server configuration, basic options I have assigned the subdomain panel.dominio.com and although it is assigned it does not direct to the host of hestiacp.
How can I make this configuration?
Thank´s
Best regard.
Thank´s
Hi
You need one A record named panel pointing to the panel ip and Add this subdomain how new domain.
Should be direct to the panel. For install ssl in console: v-add-letsencrypt-host
Thanks for your support
I really don’t know what the error is or how to correct it
Disable proxy for http://panel.domain.com/
Thanks for your contribution, in effect the cloudflare proxy server for panel.domain.com is disabled, but it still does not address the hestiacp host.
I do not know if it is necessary to do some manual configuration in bind, maybe someone in the forum could expand this information.
I still continue without being able to assign a subdomain to the hestiacp host, I have not found how to solve it, I would appreciate if someone else can contribute to reach the solution
Finally come to the solution:
Thanks for the contributions and I hope this helps other people who have the problem
