How to auto renew webmail SSL?
my domain name domain.ltd hosted on Server A (website)
Email Server (mail.domain.ltd and webmail.domain.ltd) hosted on Server B
Seem’s Webmail SSL not auto renew on Server B.
i have to renew every three month by hand on
untick checkbox
Mail- > Mail domain → Enable SSL for this domain
Mail- > Mail domain → Use Lets Encrypt to obtain SSL certificate
save
and tick checkbox again . it’s works, just need do that every three month
any idea can setup auto renew?
Check if the v-update-ssl cronjob runs on a daily basis on “server b”
Thanks your reply
look’s cron job running good
am i done something stupid ?
I create a web with mail.domain.ltd, this SSL seem can auto renew every three month
web
mail.domain.ltd
mail
domain.ltd
sorry my poor description.
for Web
/usr/local/hestia/data/users/username/ssl
can renew no problem. and did it
mail.domain.ltd similar file
for mail /home/admin/conf/mail/domain.ltd/ssl
can’t auto renew.
expired documents domain.ltd similar file (created at three month ago)
You don’t need to add mail.doman.com to web domain. ( I think it will even causing to break it)
If you request a SSL for mail domains it should update the nginx by default
Maybe hestia could warn the user if it tries to configure such subdomains to prevent this situations.
but how to set up hestia CP admin using SSL on https://mail.domain.ltd:8083
i created mail.domain.ltd for create SSL and using for hestia CP
i think that’s why i did that long time ago
Use a different hostname is the easiest method…
I had the same problem when my hostname was mail.domain.tld. Renaming it to vps.domain.tld (or whatever) fixed it.
Perhaps the subdomains mail.domain.tld and webmail.domain.tld should be banned for use as hostname.
