g6g6g11
February 26, 2021, 1:57pm
1
Hello. i installed on one VPS a website, wordpress and it is domian.com . Then i upload a videos on that domain.
then i have a another vps and website seconddomain.com
But if i copy mp4file urls from domain.com and put it on seconddomain.com it can be played. I want to allow only one domain for example seconddomain.com and block all of other websites to play my mp4 files.
I use cloduflare for both domians. Is it via ngnix possible?
eris
February 26, 2021, 2:00pm
2
Please check
Used on my website after I got on 500 euro / month extra bill for over usage and Cloudflare “banned” the website from his system or I had to pay 7000 euro / month
g6g6g11
February 26, 2021, 2:04pm
3
But cloudflare is free? or not?
and how can i configure it, is so correct?
location ~* ^.+\.(mp4|webm|mp3|ogg|ogv)$ {
proxy_cache off;
secure_link $arg_md5,$arg_expires;
secure_link_md5 "$secure_link_expires$uri secret-pass";
if ($secure_link = "") {
return 403;
if ($secure_link = "0") {
return 403;
root %sdocroot%;
access_log /var/log/%web_system%/seconddomain.com/%seconddomain.com%.log combined;
access_log /var/log/%web_system%/seconddomain.com/%seconddomain.com%.bytes bytes;
eris
February 26, 2021, 2:15pm
4
Cloudflare is “free” how ever if you more than “fair” use they can charge you money or require payment. It is still a commercial product that needs to make profit…
If you re using Nginx + Apache2 put those files in /usr/local/hestia/data/templates/web/nginx/
For Nginx you will need to modify your current template and place it in the server { } as above…
To get it working you will need to has all your video’s
function secure_url($url, $path){ $expires = time() + $this -> options['ttl']; $secret = $this -> options['secret']; $md5 = md5("$expires$path $secret", true); $md5 = base64_encode($md5); $md5 = strtr($md5, '+/', '-_'); $md5 = str_replace('=', '', $md5); //var_dump($url . $path . '?md5=' . $md5 . '&expires=' . $expires); return $url . $path . '?md5=' . $md5 . '&expires=' . $expires; }
The plugin that is included will just convert all video urls in post…
The default “key” is currently the username allowing the template to be installed on multiple sites with out an predictable outcome…
Incase of Wordpress will probably work fine
g6g6g11
February 26, 2021, 2:28pm
5
Is that correct for seconddomain.com ?
server {
listen %ip%:%proxy_ssl_port% ssl http2;
ssl_certificate %ssl_pem%;
ssl_stapling on;
ssl_stapling_verify on;
error_log /var/log/%web_system%/domains/%seconddomain.com%.error.log error;
include %home%/%user%/conf/web/%seconddomain.com%/nginx.hsts.conf*;
location = /xmlrpc.php {
deny all;
access_log off;
location / {
proxy_cache cache;
proxy_cache_valid 15m;
proxy_cache_valid 404 15m;
proxy_no_cache $no_cache;
proxy_cache_bypass $no_cache;
proxy_cache_bypass $cookie_session $http_x_update;
proxy_cache off;
secure_link_md5 "$secure_link_expires$uri %user%";
return 403;
return 403;
root %sdocroot%;
location ~* ^.+\.(%proxy_extentions%)$ {
proxy_cache off;
root %sdocroot%;
expires 1h;
try_files $uri @fallback;
location /error/ {
alias %home%/%user%/web/%seconddomain.com%/document_errors/;
location @fallback {
location ~ /\.ht {return 404;}
location ~ /\.svn/ {return 404;}
location ~ /\.git/ {return 404;}
location ~ /\.hg/ {return 404;}
location ~ /\.bzr/ {return 404;}
include %home%/%user%/conf/web/%seconddomain.com%/nginx.ssl.conf_*;
eris
February 26, 2021, 2:38pm
6
It should be ran on the domain that you want to protect…
system
Closed
March 28, 2021, 2:38pm
7
