How to change default Virtual host port from 8080 to 80?
I want new apache Virtual hosts to be created with that port by default.
This is not possible, because - if you used the default installation, nginx sits on 80/443. Is there aby reason you want to disable nginx?
Hello, I’ll ask here because I’ve already read topics about the fact that port 80 and 443 cannot be changed (you wrote so), but is it possible to somehow hide port 80 from an external definition? I want to use VPN on the same server with the panel, and if I hide port 80 from the outside, I don’t need to solve captchas. Thank you
