How to change hostname and letsencrypt certificate details
Hello ! When installing Hestia, I used a temporary domain from the hosting, when I changed the domain to my own, I lost ssl when I entered the admin panel example.com: 8083 / the message on the page displays this security certificate refers to the old domain. The question is in which folder on apache do I you need to change the hostname and letsencrypt certificate data
How about re-issuing the let’s encrypt SSL certificate on your example.com domain from web-gui
v-change-sys-hostname
v-add-letsencrypt-host
Thanks, can you give me more details on where to change hostname and how to add a new -letsencrypt-host
Login via ssh and run the commands as root
