How to config Both Cache in Nginx
I am trying to config FastCGI Cache and Proxy Cache in Nginx
I have installed Nginx + Apache2 + PHP-FPM
How I can add both?
Example:
location / {
proxy_cache %domain%;
proxy_cache_valid 200 5m;
proxy_cache_valid 301 302 10m;
proxy_cache_valid 404 10m;
proxy_cache_bypass $no_cache $cookie_session $http_x_update;
proxy_no_cache $no_cache;
set $no_cache 0;
if ($http_cookie ~ PHPSESSID) {
    set $no_cache 1;
# FastCGI Cache for PHP
location ~ [^/]\.php(/|$) {
    try_files $uri =404;
    fastcgi_index index.php;
    fastcgi_pass %backend_lsnr%;
    # FastCGI Cache rules
    fastcgi_cache %domain%;
    fastcgi_cache_valid 200 6h;
    fastcgi_cache_valid 301 302 6h;
    fastcgi_cache_valid 404 6h;
    fastcgi_cache_bypass $no_cache;
    fastcgi_no_cache $no_cache;
    set $no_cache 0;
        set $no_cache 1;
# Proxy Cache for Static Files
location ~* ^.+\.(%proxy_extensions%)$ {
    try_files $uri @fallback;
    root %sdocroot%;
    expires 30d;
    proxy_cache_valid 200 6h;
    proxy_cache_valid 301 302 6h;
    proxy_cache_valid 404 6h;
    proxy_cache_bypass $no_cache;
    set $no_cache 0;
    # Disable setting cookies for static files
    add_header X-Proxy-Cache $upstream_cache_status;
Static files are allready served directly via Nginx so there 0 speed benefits for it …
as I don’t see option in hestia for FastCGi cache
How I can Add FastCGi cache manually ??
FastCGI is only availble in Nginx only setups
It won’t worth in your case brother.
I am just trying to reduce load on DB
then use redis
