I am using two different PHP scripts first Grav and second Flarum on a domain and I wish to show common error pages in both the software, for this I tried by entering
error_page 404 /404.html;
in my Default Web Domain Template, I am including my configuration
server {
listen %ip%:%web_port%;
root %docroot%;
access_log /var/log/nginx/domains/%domain%.log combined;
access_log /var/log/nginx/domains/%domain%.bytes bytes;
error_log /var/log/nginx/domains/%domain%.error.log error;
location / {
try_files $uri $uri/ /index.php?$query_string;
location ~* ^.+.(jpeg|jpg|png|webp|gif|bmp|ico|svg|css|js)$ {
expires max;
fastcgi_hide_header “Set-Cookie”;
location ~ [^/].php(/|$) {
if (!-f $document_root$fastcgi_script_name) {
return 404;
fastcgi_pass %backend_lsnr%;
fastcgi_index index.php;
#ERROR-PAGE-START Error page configuration, allowed to be commented, deleted or modified
error_page 404 404.html;
#This rule help to read the index.php file in Flarum root folder
location /community/ {
try_files $uri $uri/ /community/index.php?$query_string;
location ~* ^/community/(.).php$ {
fastcgi_split_path_info ^(.+.php)(/.+)$;
include fastcgi_params;
#fastcgi_param HTTP_PROXY “”; # Fix for https://httpoxy.org/ vulnerability
location ~ ^/community/(.).html$ {
expires -1;
location ~ ^/community/(.).(css|js|gif|jpe?g|png)$ {
expires 1M;
add_header Pragma public;
add_header Cache-Control “public, must-revalidate, proxy-revalidate”;
gzip on;
gzip_http_version 1.1;
gzip_vary on;
gzip_comp_level 6;
gzip_proxied any;
gzip_types application/atom+xml
application/javascript
application/json
application/vnd.ms-fontobject
application/x-font-ttf
application/x-web-app-manifest+json
application/xhtml+xml
application/xml
font/opentype
image/svg+xml
image/x-icon
text/css
#text/html – text/html is gzipped by default by nginx
text/plain
text/xml;
gzip_buffers 16 8k;
gzip_disable "MSIE [1-6].(?!.SV1)";
location /error/ {
location ~ /(.git|cache|bin|logs|backup|tests)/.$ { return 403; }
location ~* /(system|vendor)/..(txt|xml|md|html|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ { return 403; }
location ~ /user/..(txt|md|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ { return 403; }
location ~ /(LICENSE.txt|composer.lock|composer.json|nginx.conf|web.config|htaccess.txt|.htaccess) { return 403; }
location ~ /.(?!well-known/) {
deny all;
return 404;
location /vstats/ {
alias %home%/%user%/web/%domain%/stats/;
include %home%/%user%/web/%domain%/stats/auth.conf;
So, any clue or suggestion where I am wrong?
