How to connect to db remotely?
Hi all. I need to connect to my db remotely to upload some data.
But the only host i have is local host
How can i Create host for DB to be able to connect remotely?
Please use the search function: Search results for 'mysql remote' - Hestia Control Panel - Discourse
Also we do have an entry in our docs for it.
I assume you want to add a supported database server such as Mysql. In such a case, kindly use v-add-database-host.
Moreover, if you want to see your remote database server in phpMyAdmin, I suggest this workaround. Feel free to improve it !
Hello.
No. I do not need phpMyAdmin
I need to have opportunity to be able to connect to my DB remotely.
When I tried to do v-add-database-host it fails with error that it is not able to connect.
you need to adjust your mysql config to allow binding to your public IP.
also you need to add a firewall rule for the database port to be allowed to be accessed from external IP. ideally you want to allow it only for a specific external IP to limit access on that level already and avoid inviting brute force attacks
