I am having Hestia running on Oracle Cloud Always Free Services. I want to host multiple websites with their subdomains. I mean that for example : subdomain1.domain.com is one site with a custom website.
subdomain2.domain.com is another website with a different custom website. How is it possible. Please help.
Just create a new site for each, treat each sub-domain as an independent site.
for example I created videocial.chiragnahata.ml. But whenever I am trying to go to this website it says not available. I am new to this platform. Please help
Make sure the DNS records exists
do as @eris says and also place a website in the public-html directory
What all DNS records to add in cloudfare. I mean can you say it as becuase i am new in Hestia.
First you need to know the basics of hosting a website, search a bit and make some tryouts.
What I can give you as hints are:
For each site:
Make sure that the place where the domain was registered has the A record (DNS settings of the domain) pointing to the IP of the server where HestiaCP is installed
In HestiaCP, create the site with the desired domain, in your case, start with the videocial.chiragnahata.ml
Place the files for your site inside the public-html directory, you can access it via FTP with the login details that you created for your user in HestiaCP, place them into the following directory: web/videocial.chiragnahata.ml/public_html
Test the site in your browser, use the domain: videocial.chiragnahata.ml
