@eris talk about a command from cron job as far as I understand.
What happens when you run that command as regular user?
Have you got any errors?
Under the {user}
/usr/bin/php /home/xxxx/web/xxxxx/public_html/wp-content/plugins/xxxx-xxxx/cronjob.php
If you login via ssh as use su user
And then run crontab -e you should be able to see the command in the list
Nothing happens. I do not receive a letter. Cron doesn’t work. I tried many times, different commands. The result is negative. I guess it doesn’t work. In any case, I would like to know that it works for others. And it’s bad that there is nothing in the wiki or documentation about the user’s cron.
I don’t use wordpress. Can’t this command work for me?
I wrote from another account, because there is a limit of 20 messages. The limit has ended.
I see.
Can you send me a private message here?
Provide with the additional details, so we communicate in Russian there in private messaging.
This might be helpful in this situations.
I found a solution to the problem. You cannot run cron manually from the server, this is already a problem. It’s strange that this hasn’t been implemented. But as is.
So when I run cron after 1 minute it doesn’t work for me. Why?
The server time has not been changed. Although I changed the time zone in the server settings. I checked the time on the site, it showed correctly.
As a result, for me, kroner worked not after a minute, but after 1 hour and 1 minute.
It remains to be understood whether it is possible to change the time on the server in the panel? Or does it have to be done manually? I found a previous topic on this issue, do I offer it manually? I don’t know how now?
Maybe Hestia could show current server time at least in the Cron page.
I ended up doing the following:
Determine where the data is being loaded from
php -i | grep php.ini
I got: /etc/php/8.0/cli/php.ini
Find value:
;date.timezone =
Set up your zone:
date.timezone = Europe/Town
Reload php8.0-fpm
The cron time works correctly.
I checked it works too
/usr/bin/wget http://site.com/cron_check.php
Curl working variant
/usr/bin/curl --silent ‘https://site.com/cron_check.php’ &>/dev/null
You have updated the caption. But all the inscriptions are in small letters. And resume (‘Возобновить’) with a big one. Looks ugly. Should be written in lower case. Or all with a big one.
You can also submit the changes via:
https://translate.hestiacp.com/projects/hestiacp/ru/default/?filters[term]=unsuspend&filters[user_login]=&filters[status]=current_or_waiting_or_fuzzy_or_untranslated&filter=Filter&sort[by]=priority&sort[how]=desc
To Create an account use the key “hestiacp”
Done, just as you wish in translation
BTW you can PM me in Russian, just in case your English is not fluent.
php -f /home/{user}/web/{domain.com}/public_html/script.php >/dev/null 2>&1
/dev/null 2>&1 >>> Disable system message
