How to create real backups of each account automatically
ok, but to clarify, there is no way to do it globally? I mean do I have to go to each version of php and disable the feature?
(that is why I am asking)
yes, you need to disable it for each version. can be done over sed with a little bit work.
thanks for your help, problem solved :+1:
