How to disable clamav-daemon and spamassassin, since I don’t really use them, I want to remove it or disable it completely so that it doesn’t consume memory!
I have 4 cores and 8 Gb ram
systemctl stop clamav-daemon
systemctl disable clamav-daemon
systemctl stop spamassassin
systemctl disable spamassassin
apt remove spamassassin clamav-daemon spamassassin
And update /etc/exim4/exim4.conf.template
And comment out:
#SPAMASSASSIN = yes
#SPAM_SCORE = 50
#SPAM_REJECT_SCORE = 100
#CLAMD = yes
Update /usr/local/hestia/conf/hestia.conf
By replacing:
ANTISPAM_SYSTEM='spamassassin'
ANTIVIRUS_SYSTEM='clamav-daemon'
With
ANTISPAM_SYSTEM=''
ANTIVIRUS_SYSTEM=''
Thank you, I have another concern, I am decompressing a 2 GB file and it does not decompress anything, can you help me?
Use ssh it goes way faster …
Also upgrade to the 1.6.14 and then is should be fixed the unzipping
And how can you explain to me? i’m a bit new
How do I update?
apt update && apt upgrade
And if it wants to replace config files enter N
I keep seeing the same thing and I already did the process
