How to disable Fast CGI Cache for specific page?
hi,
i want to bypass Fast CGI cache for all page that start with /admin
so, how to do this?
i use bellow nginx config but can’t work.
location ~ /admin/* {
    fastcgi_cache off;
    fastcgi_cache_bypass 1;
    fastcgi_no_cache 1;
    proxy_no_cache 1;
    proxy_cache_bypass 1;
thank you,
Check wordpress.tpl for example:
fastcgi.conf allready contains the skip to by pass
solved by using your tips.
open /home/admin/conf/web/domain.com/nginx.fastcgi_cache.conf and add bellow with path.
if ($request_uri ~* "/admin/*") {
   set $no_cache 1;
thank you,
Will get overwritten each update / rebuild
It is better to change it in the template file
ohh, thank you brother… :slightly_smiling_face:
