How to disable IP based login?
I have applied Cloudflare Zero Trust 2FA (OTP via Email) authentication to both HestiaCP and WordPress login pages.
The HestiaCP login page can be accessed at https://cp.mydomain.tld:2083
However, direct access to https://IP-Address:2083 bypasses Cloudflare Zero Trust 2FA.
Can you please tell me how to disable direct IP login for HestiaCP?
You would need to firewall off access to that IP and port combination from anywhere except wherever Cloudflare Access connects from.
You can’t currently
Is there any workaround using Ngnix?
The only method you can use is to block port 8083 completely and use the templates from:
cp.tpl / stpl
You probally want to change the port back to 8083 in that case (or adjust te template)
Thanks, i will look into this and let you know.
Can you please add my usecase as a feature request for the next releases of hestiacp.
Direct IP based login should be disabled.
You need to allow access only to cloudflare ips on your HestiaCP Firewall.
https://www.cloudflare.com/ips-v4/#
This works like a charm!
Thanks.
This feature is built-in in CloudPanel for security purpose.
