Hi experts,
Would you help to solve Disable “root” account web login problem? I don’t want disable root directly in Debian 10, since that cause lots of problems.
Hi experts,
Just did a check and I was surprised it worked fine (even though permitrootlogin was no / password forbidden
Remove the following line:
You will need to do it after each update currently how ever I will consider it for the future releases remove / modify it that it will become a check box…
This https://github.com/hestiacp/hestiacp/pull/1117 should fix the issue + adding a more “friendly” error message.
