How to disable strict_trans_tables
Hello. Please, friends and experienced people, help me solve this problem. How can I disable strict_trans_tables.
Important!
The sql-mode strict_trans_tables is enabled in your mysql server, please contact your host provider to disable it.
If you are running HestiaCP, you are the host provider!
Here is a link to the relevant MariaDB documentation.
Add this line into /etc/mysql/my.cf in section [mysqld]
sql-mode="ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION"
And restart mysql:
systemctl restart mysqld
Yes, it now works successfully. Thank you for your reply and help.
