I use server Nginx + PHP-FPM,
I want to pre-modify those file /etc/nginx/conf.d/fastcgi_cache_pool.conf
and /home/user/conf/web/domain.com/nginx.fastcgi_cache.conf
Hello
There are no template to modify those files, the conf used is hard coded in command /usr/local/hestia/bin/v-add-fastcgi-cache.
You can modify the script, but keep in mind that the next time Hestia is updated, the script will be overwritten and you will lose any changes you have made.
