I want to change the domain of my website…I tried to change it in hestiacp, but notice that it can’t be edited. Is is possible to do it another way?
Create a new one and move the content from old via file manager?
Hmmm…this may actually work since the database would remain the same, but what would happen if I decide not to renew the main domain? Would that affect anything
Your old domain should be an alias of the first or you should 301 redirect to the second.
If you don’t renew, you may leave the server as is or remove the old domain. If you leave the server as is, no more visits will come to your IP asking for the old web so your server will no longer redirect that traffic.
Ok. Got it. Thanks
