I have two hestia servers ns1.mydomain.com with api enabled, and ns2.mydomain.com with API disabled, I want to build a dns cluster ns1 master and ns2 slave. but I need to enable API on ns2 server. Is there a way to activate the API??
Check $HESTIA/conf/hestia.conf
Change API=‘no’ to ‘yes’
And then check if the php code is present in $HESTIA/web/api
If not download the code from Github and move the /web/api folder to $HESTIA/web/api
Then it should work fine
It worked, thank you so much
