I want to be able to enable external database connection from a specific IP address. How am I able to do that when currently MySQL is only accepting connections locally.
There are a few ways. Perhaps the simplest would be to tunnel the connection through ssh.
But if that doesn’t fit your use-case, you’d have to first, change the bind address setting in /etc/mysql/maridb.conf.d/50-server.cnf
bind-address = 127.0.0.1 # change to 0.0.0.0
Then you’d need to add a firewall rule allowing access to port 3306 from your external IP.
Finally you’d need to make sure your database user has an entry set up for Host = % which I think is the default for db users created in Hestia.
mysql -e “select User,Host from mysql.user”
| User | Host |
| onlyme | % | <---- this is what you need
| onlyme | localhost |
