Is there an explicit way to enable SFTP to users to allow them to connect securely? The current protocol for a user account is through FTP and then FileZilla prompts with a few SSL server options to select. Any Ideas will be appreciated…
One last thing, I just tried to upload a folder using FTP protocol with Use Explicit FTP Over TLS If Available encryption. It seems the process starts smoothly with (status: Server sent passive reply with unrouteable address. Using server address instead in FileZilla). The error in the post came when I’d tried to upload ZIP file, so I am wondering if Hestia FM supports zip files and extraction feature. However, still unclear to me why I couldn’t use SFTP directly at port 22?
Note: I see this error, but I am not sure how to fix it. After very lengthy timing of process, I haven’t found a guidance for this issue
Jul 6 21:08:51 talk sshd[5672]: Connection closed by authenticating user Hussein 156.208.46.14 port 52571 [preauth]
Jul 6 21:08:58 talk sshd[5680]: Connection closed by authenticating user Hussein 156.208.46.14 port 52572 [preauth]
If I use the root username and the ssh private key, it works find otherwise rejected.
