How to fix Blesta nginX Template
Hello, i’ve using nginX on my Server,
after create nginx Template for Blesta, its working Fine, But Blesta API & Feed not Working when using my nginX Template.
blesta.tpl -
server {
    listen      %ip%:%web_port%;
    # Root location block (Update %docroot%/blesta to your own Directory / @blesta is Default)
    root        %docroot%/blesta;
    # Security: Prevent access to hidden files
        deny all;
        return 404;
    # Main location block (Update @blesta to your own Directory / @blesta is Default)
    location / {
        try_files $uri @blesta;
        rewrite ^(.*)/install\.php$ /$1/install/ redirect;
    # PHP-FPM configuration for index.php
    location = /index.php {
        try_files $uri =404;
        fastcgi_index index.php;
        fastcgi_pass %backend_lsnr%;
    # Security: Block access to certain file types
    location ~ /\. {
        log_not_found off;
        return 404;
    location ~* \.(php|pdt|txt)$ {
        log_not_found off;
        return 404;
    # Error handling
    location /error/ {
        alias %home%/%user%/web/%domain%/application/app/views/errors/;
    # Stats
    location /vstats/ {
        alias %home%/%user%/web/%domain%/stats/;
    # Include additional configurations
    # Core rewrite (Update @blesta to your own Directory / @blesta is Default)
    location @blesta {
        rewrite ^(.*)$ /index.php?$1 last;
blesta.stpl -
server {
    listen      %ip%:%web_ssl_port% ssl;
    root        %sdocroot%/blesta;
    ssl_stapling        on;
    ssl_stapling_verify on;
    # TLS 1.3 0-RTT anti-replay
    # Security: HSTS
        deny all;
        return 404;
    location / {
    location ~ /\. {
        log_not_found off;
        return 404;
        log_not_found off;
        return 404;
    # Error handling
    location /error/ {
    # Stats
    location /vstats/ {
    location @blesta {
Please help me how to fix Blesta API & Feed on HestiaCP.
Thanks in Advance.
Blesta.tpl
server {
        listen  %ip%:%web_port%; # IPv4
        listen [::]:%web_port%; # IPv6
        server_name %domain_idn% %alias_idn%; # Hostname
        # iFrame protection
        add_header X-Frame-Options SAMEORIGIN;
        location / {
                try_files $uri /index.php;
                rewrite ^(.*)/install.php$ /$1/install/redirect;
                fastcgi_pass	%backend_lsnr%; # PHP socket
                fastcgi_param	SCRIPT_FILENAME $document_root/index.php; # Blesta /index.php
                fastcgi_param	SCRIPT_NAME $fastcgi_script_name;
                include         /etc/nginx/fastcgi_params;
        location ~ /\. {
                log_not_found off;
                return 404;
                log_not_found off;
                return 404;
Blesta.stpl
server {
        listen  %ip%:%web_ssl_port% ssl; # IPv4
        listen [::]:%web_ssl_port% ssl; # IPv6
        root %sdocroot%; # Installation directory
        # SSL cert/key pair
        ssl_stapling        on;
        # iFrame protection
        location / {
        location ~ /\. {
                log_not_found off;
                return 404;
                log_not_found off;
                return 404;
This is my template i didnt check exactly yours but i didnt have any problems with Blesta try with this and if your problem continues will see if its something from blesta’s side.
https://domain.com/index.php/feed/domain/pricing/?currency=USD&style=bootstrap&term=1,2,3,4,5,10 redirects to the home page and
https://domain.com/feed/domain/pricing/?currency=USD&style=bootstrap&term=1,2,3,4,5,10 never loads
I just added Few Changes now everything working fine…
If you share what you have modified, others with the same issue could resolve the issue too.
I’ve Added Blesta nginX Template on GitHub (Updated old Code) - HestiaCP/templates/nginx/php-fpm at main · KholifaNetwork/HestiaCP · GitHub
