cosmos
July 22, 2025, 9:46am
1
think as linux administrator
on the linux server with hestia installed
There are 300 domains installed
When trying restart nginx we have errors
open() “/var/log/nginx/domains/webmail.mydomain.info.log” failed (24: Too many open files)
How to fix this error?
Nginx has nest config now:
cat /proc/$(pidof apache2 | awk ‘{print $1}’)/limits | grep “Max open files”
return:
Max open files 65536 65536 files
sudo systemctl show apache2 | grep -i limitnofile
LimitNOFILE=262144
LimitNOFILESoft=262144
cat /etc/nginx/nginx.conf
# Server globals
user www-data;
worker_processes auto;
worker_rlimit_nofile 65535;
error_log /var/log/nginx/error.log;
pid /run/nginx.pid;
include /etc/nginx/conf.d/main/*.conf;
include /etc/nginx/modules-enabled/*.conf;
# Worker config
events {
worker_connections 512;
use epoll;
multi_accept on;
http {
# Main settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
client_header_timeout 180s;
client_body_timeout 180s;
client_header_buffer_size 2k;
client_body_buffer_size 256k;
client_max_body_size 1024m;
large_client_header_buffers 4 8k;
send_timeout 60s;
keepalive_timeout 30s;
keepalive_requests 1000;
reset_timedout_connection on;
server_tokens off;
server_name_in_redirect off;
server_names_hash_max_size 512;
server_names_hash_bucket_size 512;
charset utf-8;
# FastCGI settings
fastcgi_buffers 512 4k;
fastcgi_buffer_size 256k;
fastcgi_busy_buffers_size 256k;
fastcgi_temp_file_write_size 256k;
fastcgi_connect_timeout 30s;
fastcgi_read_timeout 300s;
fastcgi_send_timeout 180s;
fastcgi_cache_lock on;
fastcgi_cache_lock_timeout 5s;
fastcgi_cache_background_update on;
fastcgi_cache_revalidate on;
# Proxy settings
proxy_redirect off;
proxy_set_header Host $host;
proxy_set_header Early-Data $rfc_early_data;
proxy_pass_header Set-Cookie;
proxy_buffers 256 4k;
proxy_buffer_size 32k;
proxy_busy_buffers_size 32k;
proxy_temp_file_write_size 256k;
proxy_connect_timeout 30s;
proxy_read_timeout 300s;
proxy_send_timeout 180s;
# Log format
log_format main '$remote_addr - $remote_user [$time_local] $request "$status" $body_bytes_sent "$http_referer" "$http_user_agent" "$http_x_forwarded_for"';
log_format bytes '$body_bytes_sent';
log_not_found off;
access_log off;
# access_log /var/log/nginx/combined.log;
error_log /var/log/nginx/error.log crit;
# Mime settings
include /etc/nginx/mime.types;
default_type application/octet-stream;
# Compression
gzip on;
gzip_vary on;
gzip_static on;
gzip_comp_level 6;
gzip_min_length 1024;
gzip_buffers 128 4k;
gzip_http_version 1.1;
gzip_types text/css text/javascript text/js text/plain text/richtext text/shtml text/x-component text/x-java-source text/x-markdown text/x-script text/xml image/bmp image/svg+xml image/vnd.microsoft.icon image/x-icon font/otf font/ttf font/x-woff multipart/bag multipart/mixed application/eot application/font application/font-sfnt application/font-woff application/javascript application/javascript-binast application/json application/ld+json application/manifest+json application/opentype application/otf application/rss+xml application/ttf application/truetype application/vnd.api+json application/vnd.ms-fontobject application/wasm application/xhtml+xml application/xml application/xml+rss application/x-httpd-cgi application/x-javascript application/x-opentype application/x-otf application/x-perl application/x-protobuf application/x-ttf;
gzip_proxied any;
# Cloudflare IPs
include /etc/nginx/conf.d/cloudflare.inc;
# SSL PCI compliance
ssl_buffer_size 1369;
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:DHE-RSA-AES256-SHA256";
ssl_dhparam /etc/ssl/dhparam.pem;
ssl_early_data on;
ssl_ecdh_curve auto;
ssl_prefer_server_ciphers on;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_session_cache shared:SSL:20m;
ssl_session_tickets on;
ssl_session_timeout 7d;
resolver 127.0.0.53 valid=300s ipv6=off;
resolver_timeout 5s;
# Error pages
error_page 403 /error/404.html;
error_page 404 /error/404.html;
error_page 410 /error/410.html;
error_page 500 501 502 503 504 505 /error/50x.html;
# Proxy cache
proxy_cache_path /var/cache/nginx levels=2 keys_zone=cache:10m inactive=60m max_size=1024m;
proxy_cache_key "$scheme$request_method$host$request_uri";
proxy_temp_path /var/cache/nginx/temp;
proxy_ignore_headers Cache-Control Expires;
proxy_cache_use_stale error timeout invalid_header updating http_502;
proxy_cache_valid any 1d;
# FastCGI cache
fastcgi_cache_path /var/cache/nginx/micro levels=1:2 keys_zone=microcache:10m inactive=30m max_size=1024m;
fastcgi_cache_key "$scheme$request_method$host$request_uri";
fastcgi_ignore_headers Cache-Control Expires Set-Cookie;
fastcgi_cache_use_stale error timeout invalid_header updating http_500 http_503;
add_header X-FastCGI-Cache $upstream_cache_status;
# Cache bypass
map $http_cookie $no_cache {
default 0;
~SESS 1;
~wordpress_logged_in 1;
# File cache (static assets)
open_file_cache max=10000 inactive=30s;
open_file_cache_valid 60s;
open_file_cache_min_uses 2;
open_file_cache_errors off;
# Wildcard include
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/conf.d/domains/*.conf;
cosmos
July 22, 2025, 9:47am
2
I suppose that too much error logs files trying to open /var/log/nginx/domains/webmail.mydomain.info.log
but I cant disable logging. I didnt find the appropriate config template
nu01
July 22, 2025, 10:47am
3
Open files are limited to 1024. Suggest to set it to a higher limit of say 65535.
Set it for your PHP version (example PHP8.2):
mkdir -p /etc/systemd/system/php8.2-fpm.service.d/
echo -e "[Service]\nLimitNOFILE=65535" > /etc/systemd/system/php8.2-fpm.service.d/override.conf
systemctl daemon-reload
systemctl restart php8.2-fpm.service
Check again that open files limit has been raised:
cat /proc/$(pgrep -f 'master.*php\/8\.2' | head -n1)/limits
cosmos
July 22, 2025, 11:37am
4
well I had tried as your wrote but with no luck
althow now limits have rised
cat /proc/$(pgrep -f ‘master.*php/8.1’ | head -n1)/limits
Limit Soft Limit Hard Limit Units
Max cpu time unlimited unlimited seconds
Max file size unlimited unlimited bytes
Max data size unlimited unlimited bytes
Max stack size 8388608 unlimited bytes
Max core file size 0 unlimited bytes
Max resident set unlimited unlimited bytes
Max processes 63797 63797 processes
Max open files 262144 262144 files
Max locked memory 65536 65536 bytes
Max address space unlimited unlimited bytes
Max file locks unlimited unlimited locks
Max pending signals 63797 63797 signals
Max msgqueue size 819200 819200 bytes
Max nice priority 0 0
Max realtime priority 0 0
Max realtime timeout unlimited unlimited us
The major thing was this limit
ulimit -Sn
1024
it still has small value
I have raised it by
ulimit -S -n 66048
but is it permanent solution?
I am afraid no, how to change it permanently?
nu01
July 22, 2025, 12:12pm
5
cosmos:
ulimit -Sn
Your All-in-One Learning Portal: GeeksforGeeks is a comprehensive educational platform that empowers learners across domains-spanning computer science and programming, school education, upskilling, commerce, software tools, competitive exams, and...
https://www.baeldung.com/linux/ulimit-tutorial
Set the soft limit as say 65576 with sysctl -w fs.file-max=65576
cosmos
August 8, 2025, 9:48am
6
Sorry, I dont know why but again I should back with the same error
I have read two articles above
and changed configs as it described there, butt eror still happend.
So now my current configs is:
Still cant change 1024 value:
ulimit -Hn
1048576
ulimit -Sn
1048576
cat /proc/$(pgrep -f ‘nginx’ | head -n1)/limits | grep “Max open”
Max open files 1024 524288 files
sudo nginx -T
failed with error
nginx: [emerg] open() “/var/log/nginx/domains/webmail.test.com.log” failed (24: Too many open files)
nginx: configuration file /etc/nginx/nginx.conf test failed
How to increase SOFT LIMIT for Max open files?
Pls help me !
cosmos
August 8, 2025, 10:02am
7
:/etc/nginx# cat /proc/$(pgrep -f ‘master.*php/8.1’ | head -n1)/limits | grep “Max open file”
:/etc/nginx# cat /proc/$(pgrep -f ‘master.*php/8.0’ | head -n1)/limits | grep “Max open file”
:/etc/nginx# cat /proc/$(pgrep -f ‘master.*php/8.2’ | head -n1)/limits | grep “Max open file”
:/etc/nginx# cat /proc/$(pgrep -f ‘master.*php/8.3’ | head -n1)/limits | grep “Max open file”
:/etc/nginx# php -v
PHP 8.1.31 (cli) (built: Nov 21 2024 13:10:15) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.1.31, Copyright (c) Zend Technologies
with Zend OPcache v8.1.31, Copyright (c), by Zend Technologies
As I see for current php version used on my server 8.1
limits was raised but it doesnt fix the issue;
As root:
systemctl edit nginx.service
This will open the file /etc/systemd/system/nginx.service.d/override.conf so you need to add two lines between the comments, as shown below:
### Editing /etc/systemd/system/nginx.service.d/override.conf
### Anything between here and the comment below will become the new contents of the file
[Service]
LimitNOFILE=250000
### Lines below this comment will be discarded
### /etc/systemd/system/nginx.service
Save the file and restart nginx
systemctl restart nginx.service
Check again the limits and also nginx:
cat /proc/$(cat /var/run/nginx.pid)/limits | grep -i 'Max open files'
nginx -t
cosmos
August 8, 2025, 11:27am
9
I 've changed the file
and restart nginx
nginx t
still failed
It doesnt change
ps: Can I nurn off webmail.test.com.log logs, to decrease number of open files?
this is my /etc/nginx/nginx.conf
[details="Спойлер"]
# Server globals
user www-data;
worker_rlimit_nofile 262144;
pid /run/nginx.pid;
# Worker config
events {
use epoll;
multi_accept on;
http {
# Main settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
send_timeout 60s;
server_tokens off;
charset utf-8;
# FastCGI settings
# Proxy settings
proxy_redirect off;
# Log format
log_not_found off;
access_log off;
# Mime settings
# Compression
gzip on;
gzip_vary on;
gzip_static on;
gzip_comp_level 6;
gzip_proxied any;
# Cloudflare IPs
ssl_early_data on;
# Error pages
# Proxy cache
# FastCGI cache
# Cache bypass
default 0;
~SESS 1;
# Wildcard include
[/details]
cosmos:
It doesnt change
It doesn’t change because Nginx can’t restart.
killall nginx or restart the server and the change should be done.
cosmos
August 8, 2025, 11:57am
11
Unfortinally killall nginx doesnt help,
The final way is to rebuild server but I am dont want to do it in Friday,
i am afraid that possible I will have big problem if it doesnt up after rebulding.
I wiil try this method in Monday.
Thanks for helping me man.
By the way can I decrease max open files if I cant inc max open limits?
I 've already combined in single file access logs and error logs for all domains,
but the issue refere to webmail.mydomain.com.lo files?
Force the kill:
killall -9 nginx
You don’t need to rebuild the server. If the above command doesn’t work, reboot the server.
