Hello guys,
I want to delete an IP, but I can’t because some webdomains uses it, but i cant delete them too (they exist but they dont show in panel).
How can I FORCE delete IP from hestia config
If it does not affect the use, it is recommended not to delete it, so as to avoid other errors and increase your workload!
Update /usr/local/hestia/data/ips/192.168.0.102 the WEB_DOMAINS=3 to 0
And then try again
It should be /usr/local/hestia/data/ips/192.168.0.102
