How to increase upload limit in FM?
Hi, i cannot upload file more than 1GB in FM. I updated config as it is described here:How to increase max upload size in filemanager? - #2 by eris
but i cannot still upload file over 1GB
I gave up with that. I connect via SCP or FTP
you mean winscp? how can i connect with it to ftp?
Option 1: Acces via SCP
As admin:
  • Login to hestia
  • Look for the user
  • Edit user
  • Add SSH access: bash
  • Save
Winscp
  • Protocol SCP
  • Server: my.server.com
  • Port: 22 (your SSH port I use a different one)
  • Username
  • Password
**** EDIT ****
Option 2: Access via SFTP
No need to grant SSH access.
Winscp
  • Protocol SFTP
  • Username
  • Password
SSH access is not need to connect over sftp. I think Winscp also support sftp. Never used it to be honest.
That’s right too. Just use SFTP protocol over ssh port
Keep ssh to nologin is fine then and you have an secure sftp jail…
You can copy files like that BUT… how about unzip 2GB large files over the panel? Will it work?
the File Manager in HestiaCP is capped by its own FileGator config plus the Hestia panel’s NGINX and panel PHP, not your website PHP. Here’s the working fix to upload >1 GB (example below sets 2 GB; raise as you like):
1) Raise the File Manager’s own cap (FileGator)
sudo nano /usr/local/hestia/web/fm/configuration.php
Find the line like:
$dist_config["frontend_config"]["upload_max_size"] = 1024 * 1024 * 1024;
Change it to (for 2 GB):
$dist_config["frontend_config"]["upload_max_size"] = 2 * 1024 * 1024 * 1024;
Save. This removes the File Manager’s UI hard-stop at 1 GB
