hello
i need urgent help to install node js on my server, it is my first time im using node js, i want to host a website which made in node js,
im using apache as main and nginx as proxy server
im seen some old post but still not sure, and scare to effect my other websites, can u please tell me from where to start, can you please guide me or send me tutorial link to how to install node js on my server,
please help me with it , really thank full to you
Hi. The panel does not support working with nodejs out of the box. You need to install and configure custom configs yourself.
thats what im asking there is any good tutorial in detail please ?
nu01
July 23, 2025, 4:29am
5
I use NodeJS for few of my projects. Although the default settings as I do not need that many changes to config options.
I install Node via NPM from APT.
There is one unofficial way from couple of users here: GitHub - JosephChuks/hestiacp-nodejs: HestiaCP-NodeJS | This plugin allow install multiple nodejs apps using HestiaCP (forked & updated) & GitHub - JLFdzDev/hestiacp-nodejs: HestiaCP-NodeJS | This plugin allow install multiple nodejs apps using HestiaCP (old)
Go through them once, as they still work. Otherwise use apt-get install nodejs -y to install the current debian recommended one.
Just ensure to have the binaries in /opt folder.
There are various tutorials, but trouble is, you need to have some basic knowledge. I usually **do not** follow itsfoss or itslinuxfoss, but otherwise most of the other tutorials work oob for me. install nodejs on debian12 (web)
im follow these all steps but still not working. im using this (GitHub - JosephChuks/hestiacp-nodejs: HestiaCP-NodeJS | This plugin allow install multiple nodejs apps using HestiaCP )
im using ubuntu
result, Access Denied
You do not have permission to view this page.
Please check your credentials and try again.
Error Code: 403
nu01
February 21, 2026, 5:50pm
7
Hey sorry, did not realize you had responded. Did this error get resolved? Were you able to get it worked?
