How to make custom config for ssl
hey so I’m installing Pterodactyl on the same VPS that the Hestia is on, however, I’m struggling to make the proxy for it. I’ve got the stl file however I’m not sure if I’m even doing it right. Here are the pterodactyl docs: Webserver Configuration | Pterodactyl
Here is my tpl file:
server_tokens off;
server {
    listen %proxy_port%;
    server_name %domain%;
    return 301 https://$server_name$request_uri;
server {
    listen %proxy_ssl_port% ssl http2;
    root /var/www/pterodactyl/public;
    index index.php;
    access_log /var/log/nginx/pterodactyl.app-access.log;
    error_log  /var/log/nginx/pterodactyl.app-error.log error;
    # allow larger file uploads and longer script runtimes
    client_max_body_size 100m;
    client_body_timeout 120s;
    sendfile off;
    # SSL Configuration - Replace the example <domain> with your domain
    ssl_certificate %ssl_pem%;
    ssl_session_cache shared:SSL:10m;
    ssl_protocols TLSv1.2 TLSv1.3;
    ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:E>
    ssl_prefer_server_ciphers on;
    # See https://hstspreload.org/ before uncommenting the line below.
    # add_header Strict-Transport-Security "max-age=15768000; preload;";
    add_header X-Content-Type-Options nosniff;
    add_header X-XSS-Protection "1; mode=block";
    add_header X-Robots-Tag none;
    add_header Content-Security-Policy "frame-ancestors 'self'";
    add_header X-Frame-Options DENY;
    add_header Referrer-Policy same-origin;
    location / {
        try_files $uri $uri/ /index.php?$query_string;
    location ~ \.php$ {
        fastcgi_split_path_info ^(.+\.php)(/.+)$;
        fastcgi_pass unix:/run/php/php8.1-fpm.sock;
        fastcgi_index index.php;
        include fastcgi_params;
        fastcgi_param PHP_VALUE "upload_max_filesize = 100M \n post_max_size=100M";
        fastcgi_param HTTP_PROXY "";
        fastcgi_intercept_errors off;
        fastcgi_buffer_size 16k;
        fastcgi_buffers 4 16k;
        fastcgi_connect_timeout 300;
        fastcgi_send_timeout 300;
        fastcgi_read_timeout 300;
    location ~ /\.ht {
        deny all;
There is a stpl file that I need too, I’m not sure how to do that either. Any help would be appreciated!
i also need this information, and im assuming if discord was still a thing we would of got are answer much faster yet no one addressed this, im unable to see the templates on the panel either its so frustrating
