Raphael
September 16, 2021, 6:41am
2
Really?
Did you click already on edit domain?
erwin
September 16, 2021, 6:42am
4
yes i have…but still disable
Raphael
September 16, 2021, 6:43am
5
Then THIS is what you need to give us: There is an error message… What’s your hestiacp version?
erwin
September 16, 2021, 6:49am
6
how to know , what version my server ? i still not update since install hestia one years ago… how to update this ?
Raphael
September 16, 2021, 6:51am
7
apt update && apt upgrade, but if you run a server, you should also know how to maintain it. There are security issues on a regular base, not only in hestia, also for exim. You need to keep your server up to date! Please upgrade it and check again, if the issue still occures.
erwin
September 16, 2021, 7:00am
9
is it right ? how to know that my step has been succes ?
Raphael
September 16, 2021, 7:05am
10
… honestly, no - you got a lot of error messages there …
You’re logged in with admin user, i suggest to use either sudo apt update && apt upgrade of it or login as root user.
Please be aware, that you need to have some basic knowledge to run a server on your own - otherwise we will get another ddos bot member easily. It’s not a problem to start learning linux and how to run it - but hestia, inlcuding its support channels like forum and/or discord arent build for this process, we expect you to already have such a knowledge:
Please read this, before you start!
HestiaCP is not an autopilot for your server. Hestia is a tool to enable various hosting related settings via a web interface.
We assume that you are familiar with the basics of server administration, as well as knowledge about setting up and managing hosting applications. This means we assume that even without Hestia you would be able to set up a LAMP stack and manage your email, but are looking for a tool to simplify these tasks.
We cannot provide support …
erwin
September 16, 2021, 4:07pm
11
yesss, sir, thks for suggestion…
erwin
September 16, 2021, 4:08pm
12
dear sir, after i update and upgrade, the view like this
how the next step ?
erwin
September 16, 2021, 4:12pm
13
is this Index.html ?? but i am not sure
eris
September 16, 2021, 4:18pm
14
You probably overwrote nginx.conf during the update please check:
Hmm strange. After I got a message “Your new web server is ready to use.” I did login to ssh and used commands.
apt-get update
apt-get upgrade
next time will know thanks for support. You guys are best
erwin
September 17, 2021, 6:06am
16
YES SUCCESSFULLY to make SSL enable, but i am still confuse to solve writing ( Succes Your new web server is ready to use ),
Raphael
17
As @eris already wrote, you’ve overwritten the default nginx.conf file, revert it according to the other thread and restart the nginx service.
erwin
September 17, 2021, 6:17am
18
my i know commnad to restart the nginx service ?
Raphael
September 17, 2021, 6:20am
19
Raphael:
Please read this, before you start! HestiaCP is not an autopilot for your server. Hestia is a tool to enable various hosting related settings via a web interface. We assume that you are familiar with the basics of server administration, as well as knowledge about setting up and managing hosting applications. This means we assume that even without Hestia you would be able to set up a LAMP stack and manage your email, but are looking for a tool to simplify these tasks. We cannot provide support …
… systemctl restart nginx
system
Closed
October 17, 2021, 6:21am
20
