@jlguerrero
Thanks for this guide. But I’m still not able to get this right.
Please see if this screenshot is right.
I’d really appreciate your kind guidance here.
@jlguerrero
Should be domain.com
Also my experience it is extremely important to have at least 2 server available for secondary DNS. With out it it will only cause issue at a later time.
Thanks. So are you saying instead of inputting ns1, ns2 etc, I should simply input @ or ** ?
Please clarify.
Thanks for your kindness
Thanks. But these are exactly the first 2 records I have in my screenshot above
This screenshot shows
ns1 NS 144400. ip
and
ns2 NS 144400. ip
Should be removed
Thanks. I’ve deleted them and this is what I have now for nearly 30 minutes. But it isn’t working yet. dnschecker.org and intodns are still pointing out issues with A records
@jlguerrero @eris please help me. I’m just stuck on here.
What is the domain name?
torrensia.ml
Do you think this will be resolved if I delete and recreate DNS zones afresh? This is driving me nuts.
root@dev:~# whois torrensia.ml
WHOIS lookup for TORRENSIA.ML can temporarily not be answered. Please try again.
ERROR: domain not found:
root@dev:~#
Doesn’t exists
Thank you so much. I have now changed the domain and the new one is working very fine. I appreciate you kind assistance.
