I have been trying to deny all and allow IP only for location: /admin
But It not working, please any help.
where should I add the rule for admin.
location /admin {
allow 15.235.0.1;
allow 15.235.0.1;
deny all;
error_page 404 = /404.php;
try_files $uri $uri/ =404;
location ~ \.php$ {
deny all;
My config Files:
nginx.ssl.conf:
server {
listen %ip%:%web_ssl_port% ssl;
root %sdocroot%;
access_log /var/log/nginx/domains/%domain%.log combined;
access_log /var/log/nginx/domains/%domain%.bytes bytes;
error_log /var/log/nginx/domains/%domain%.error.log error;
ssl_certificate %ssl_pem%;
ssl_stapling on;
ssl_stapling_verify on;
# TLS 1.3 0-RTT anti-replay
location = /favicon.ico {
log_not_found off;
access_log off;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
deny all;
return 404;
location / {
location ~* ^.+\.(jpeg|jpg|png|webp|gif|bmp|ico|svg|css|js)$ {
expires 3d;
location ~ [^/]\.php(/|$) {
try_files $uri =404;
fastcgi_index index.php;
fastcgi_pass %backend_lsnr%;
if ($request_uri ~* "/admin/|index.php") {
set $no_cache 1;
location /error/ {
location /vstats/ {
alias %home%/%user%/web/%domain%/stats/;
proxy_hide_header Upgrade;
/home/user/conf/web/domain.com/nginx.conf_rewrite
location ~* /contents/.*\.php$ {
internal;
location /admin/data/ {
internal;
location /admin/logs/ {
internal;
location /admin/plugins/ {
internal;
location /admin/smarty/ {
internal;
location /admin/stamp/ {
internal;
location /admin/template/ {
internal;
location /admin/tools/ {
internal;
location /blocks/ {
internal;
location /template/ {
internal;
location /tmp/ {
internal;
location /langs/ {
internal;
# admin panel rewrites
rewrite ^/admin/posts_for_(.*)\.php$ /admin/posts_for_types.php?post_type_external_id=$1 last;
rewrite ^/admin/feeds/(.*)/$ /admin/feeds/get_feed.php?external_id=$1 last;
rewrite ^/admin/api/.php$ /admin/api/api.php last;
rewrite ^/admin/billings/([^/]*)\.php$ /admin/billings/$1/$1.php last;
