I did a big mistake, I wanted to remove only php redis (because for some reason when I have it my wordpress backend is loading in 10 seconds (analyzed with Query Monitor) and without it it’s 1 second, so I asked chatgpt for a command that I copy/pasted which deleted php…
sudo apt-get remove php8.3 php8.3-common
But now even if I reinstall php, it seems that it isn’t loaded, so I think hestiacp might have its own version of php?
Is there a way to re download it?
Thanks in advance!
Note: If i do v-add-web-php 8.3 I get this:
W: An error occurred while verifying the signature. The repository is not updated and previous index files will be used. GPG error: https://nginx.org/packages/mainline/ubuntu jammy InRelease: The following signatures are invalid: EXPKEYSIG ABF5BD827BD9BF62 nginx signing key <[email protected]>
W: Unable to recover https://nginx.org/packages/mainline/ubuntu/dists/jammy/InRelease The following signatures are invalid: EXPKEYSIG ABF5BD827BD9BF62 nginx signing key <[email protected]>
W: Some index files failed to download, were skipped, or old ones were used instead.
Installing PHP-8.3, please wait...
Which ends up with php installed but nginx won’t launch
I which to be as good as you are one day, you really have an answer for everything haha, thank you so much!
I got this:
sept. 09 07:06:23 mypaneldomain systemd[1]: Starting nginx - high performance web server...
sept. 09 07:06:24 mypaneldomain nginx[823]: nginx: [emerg] bind() to vpsip:80 failed (98: Address already in use)
sept. 09 07:06:25 mypaneldomain nginx[823]: nginx: [emerg] bind() to vpsip:80 failed (98: Address already in use)
sept. 09 07:06:26 mypaneldomain nginx[823]: nginx: [emerg] bind() to vpsip:80 failed (98: Address already in use)
sept. 09 07:06:27 mypaneldomain nginx[823]: nginx: [emerg] still could not bind()
sept. 09 07:06:27 mypaneldomain systemd[1]: **nginx.service: Control process exited, code=exited, status=1/FAILURE**
sept. 09 07:06:27 mypaneldomain systemd[1]: **nginx.service: Failed with result 'exit-code'.**
sept. 09 07:06:27 mypaneldomain systemd[1]: **Failed to start nginx - high performance web server.**
Edit: Ohh I see it was apache that got installed with php for some reason, I removed it with sudo apt-get remove apache2, hope it’s ok because I now get “Bad gateway” haha
Edit 2 : Okay rebuilding all the the web domains seems to have done it! I’m almost done, there is just fail2ban that won’t launch and everything is good haha
