Hi, Thanks for the info.
as for the api.
i can see that i can create subdomain and new db.
but how i can “clone” all the wp files to new subfolder or subdomain?
WP MU not feet my needs. by thanks for suggestion.
as for the command line, i am looking for automation solution using php.
i have little experience with bash.
For sure I will share with you my scripts when I have finished them. And then you will realize my shitty skills. If I have not made a pull request yet is because my lack of ability not because of laziness.
Does this mean that after a custom installation and I would like to install exim, I would need to re-install the panel to install exim or is there a way to add it after install?
You could check the related installer file and go trough the steps manually. If you know what you’re doing, you can try it, if not - reinstallation would be the better way. You can also use the backup function to quickly migrate your services.
